door PiZdeK6_ » 28 feb 2011 19:11
BT is an manual engine like you say but the engines are not the same so BT engine don't fit on the automatic... in the future I will do an automatic with tomos apn engine, yunior clynder and 21 mm carb. somthing like this : http://www.youtube.com/watch?v=WCd_Os2n ... re=relatedWhy not a BT 5 manual engine
door 2pac » 12 mar 2011 10:51
Ahh niceBT is an manual engine like you say but the engines are not the same so BT engine don't fit on the automatic... in the future I will do an automatic with tomos apn engine, yunior clynder and 21 mm carb. somthing like this : http://www.youtube.com/watch?v=WCd_Os2n ... re=relatedWhy not a BT 5 manual engine
door PiZdeK6_ » 26 apr 2011 20:41
yes yesAhh niceBT is an manual engine like you say but the engines are not the same so BT engine don't fit on the automatic... in the future I will do an automatic with tomos apn engine, yunior clynder and 21 mm carb. somthing like this : http://www.youtube.com/watch?v=WCd_Os2n ... re=relatedWhy not a BT 5 manual engine
