Airsal vs. Parma kit
Whitch is best?
Airsal
7
41%
Parma
10
59%
Totaal aantal stemmen: 17
Je stem is verwerkt.
AljazK
Contacteer AljazK
Berichtdoor AljazK » 06 nov 2007 14:24
Hay. I am from Slovenia, and I need your help. Please tell me whitch kit is best, Parma kit or Airsal kit.
Please tell me whitch kit has more power (KW), and bigger top end.
Please paste pictures ehitch sees diffrence in canals between Airsal kit and Parma kit.
Please write replays in english, because I don't understand your own language.
Thanks. :wink:
Tomos Automatic A35:
Cilinder: Airsal 65 ccm
Uitlaat: MF power Cobra
Carb: Dellorto sha 16/16 G
TWV: Voor26, Achter 19 (Home made 19 sprocket)
Top End: 80 km/h
IxilTomos
Berichtdoor IxilTomos » 06 nov 2007 18:43
Easy, I've had both Airsal 65 and Parmakit 70. Parmakit blows the dust out of airsal 65. topspeed differs for about 10 km/h, a bit less I think, and Parmakit accelerates way better than the airsal cylinder. Only problem is that you will have to tune your caser in order to get the extra power that the parmakit cylinder will supply.
Good luck
HenkieMetZeTomos
Contacteer HenkieMetZeTomos
Berichtdoor HenkieMetZeTomos » 06 nov 2007 19:29
and ofcourse the parmakit is more expensive, but i would also go for the parmakit.
good luck!
50cc
Bromkop Afgevlakt
Koppelingsveren Ingekort
Polini Membraam
Krukas Opgevult
14.9:-( (als iemand een 15/15 heeft, pm me dan a.u.b.)
Standard Brom Uitlaat
ATW 22
Top: 55
Terug naar “Afstellen”
Gebruikers op dit forum: Google [Bot] en 10 gasten
