Pagina 2 van 2
Geplaatst: 12 mar 2006 20:46
door jboy
damn why the road rage?
Geplaatst: 13 mar 2006 01:41
door Saabsonettguy
Alot of people over here don't view mopeds as serious transportation, they are usually the ones driving huge Sport utility vehicles. Heres a question, what do you guys do with your A-35 clutches? Do you stick with the stock cork clutch shoes?
Geplaatst: 13 mar 2006 17:43
door jboy
hm yes....atleast i do.... what do you do
with it?
Geplaatst: 13 mar 2006 19:04
door Saabsonettguy
Right now I'm using the stock clutches, but i'm working on building a set of race clutches. On the left are the stock clutches with no material, on the right is the clutch pads I intend to use.
I'm not sure if they will grip better but they should at least last longer with a modified engine.
Geplaatst: 13 mar 2006 19:07
door jboy
damn thats some great shit..if it works out
...if you accomplesh (
soory bad english). you maybe can write a "how to" about it
Geplaatst: 13 mar 2006 19:31
door fido
We here at the forum are very interested in reinforced clutches
If you succeed you will be the first on this forum with a real race-clutch.
Geplaatst: 13 mar 2006 20:01
door jboy
Geplaatst: 15 mar 2006 18:45
door Vuile Beunkoe
wel it looks good
but is not going to work perfect on a good modified engine.
The problem is not the gripping surface, but the segments are "gegoten" aluminium. They brake with the slightest perfomance.
better take a look in my project page, you'll probably understand the plans.
but i wish you goodluck.
and btw,
dont you shorten te spring? 1st clucht by minimum of 1 cm, and the second clutch a cm of 3? then you can use the power that your engine can generate. You'll shift later, and at the right time, so you will not have dips
Geplaatst: 15 mar 2006 21:01
door Saabsonettguy
I see, I haven't broken any clutches yet, just worn the pads off but I'm not putting out alot of power. Your clutch design looks real good.
Update: 3/16/06
Geplaatst: 17 mar 2006 03:50
door Saabsonettguy
Got the wheel painted and have a small plastic fender test mounted, I'm not sure I'll keep it though.
I've also got a 10k tachometer which should work out good.
Geplaatst: 17 mar 2006 09:35
door Tossie
I liked the gold ''subaru'' color better
But I like it 2 this way
Geplaatst: 17 mar 2006 09:56
door Vuile Beunkoe
hmz how do you mount the Rpm counter?
I had a solution by mounting it on the flywheel, so it really measures realtime RPM. But unfortunately my waterpump gos on now.
(its only an idea, not really worked out)
Geplaatst: 17 mar 2006 12:48
door jboy
ey those rms look pretty good...and the rear fender looks good to i would keep it...
a tachometer...
Cool!
Geplaatst: 17 mar 2006 17:46
door Saabsonettguy
This tachometer hooks up with 2 wires, one hooks up to power and the other connects to the coil.
Geplaatst: 25 mei 2006 20:00
door Saabsonettguy
Geplaatst: 25 mei 2006 20:08
door jboy
and u have a new spoiler for your cilinder...WOW that exhaust looks pretty good
Geplaatst: 25 mei 2006 22:15
door Vuile Beunkoe
isn't it the one that the other canadian fellow bought from that moped tuner? And that its has a flaw and is prduced wrongly?
Geplaatst: 26 mei 2006 00:36
door Saabsonettguy
Yea, its the same pipe. He was using it on a 65cc, it seems to work fine for my 50cc cylinder. The pipes we both got were from the 1st batch of 10 made or something like that so there were bound to be some issues, but they should be fixed for later batches. I thought it would be more of a bottom and mid range power pipe, but it seems to really help higher up in the rpm's. I'm going to weld on a larger head pipe at a later date and see if that adds any extra power.
