Tomos BT90 project
Geplaatst: 04 mar 2011 20:00
Hello
Greetings from Slovenia
First i mus say... nice forum you got here
Let me introduce you my project
It all started when i bought tomos BT 50N and then start restoring it :
now it is waiting
than i started engine tunning
at first... two boosts
and than... 4 boosts
exhaust is 190° transfer 130°
i also made a reed-valve take-in
step 1- welding
step 2- making hole
i already enlarged the hole, so the reed valve have enought space for opening
i still have to polish it
then i bought bigger carburator- dellorto PHBH28
then one day, i was bored, and i modified serial MF3
and i allready made a plan for custom exhaust
than there was another boring day and i decided to make a plan for 6 speed gearbox
.. but 6 is too few... so i decided to make it seven
but there was some problems becouse of one screw hole, and instead of replacing the whole screw location, i desided to make 6 speed gearbox, but with gears from 2 to 7
6th and 7th gear from the secondary transmission
i also had to modify "frame" of engine to fit it in. the distance from sprocket and alluminium is 0,4 mm
than i had to amplify clutch drum
the top ring is stil under construction
than i ordered better bearings for crankshaft
FAG NJ 203 ECP
i have ordered better big-end bearing -silver cage and more needles- for connecting rod too. But i didnt get it yet, becouse tey do not sell it in our country. So i have ordered it from your country- from EMOT.nl GOD BLESS NETHERLANDS
The crankshaft still needs to be build:
there is enought material for 4 excellent and one bad crankshaft
and a difference between tomos 80-90cc original connecting rod- the gray one and the one which is made in Serbia this days.
a few things have to be done, but i must wait to get all the bearings.
18 horsepowers is expected- by calculations
i spend 1100€till now, and next week i will give the cylinder to renewal-- new nikasil--- +100€
comments and critics welcome
now it is waiting
step 1- welding
step 2- making hole
FAG NJ 203 ECP
