Blok A3 met encarwi A11 carburateur, war is een goede vervanger
Geplaatst: 22 nov 2020 14:47
door JB67
Wat is een goed vervanger voor de Encarwi A11 Carburateur. De oude carburateur lekt flink benzine.
Re: Blok A3 met encarwi A11 carburateur, war is een goede vervanger
Geplaatst: 22 nov 2020 17:47
door fons716
Wat lekt er dan, sluit de vlotter bv niet meer af.
https://myronsmopeds.com/category/carburetor/encarwi/
Things that cause too much gas:
Worn float needle tip. Remedy is to sharpen it. Examine the tip with a magnifier. Spin the float with a drill while pressing the tip gently against a sheet of emery cloth or very fine sandpaper, at the same angle, and move it slowly around to fresh parts of the sandpaper. The needle rod must be straight first. Examine the tip with a magnifier. There should be, everywhere on the cone tip, circular sanding marks, and no more circular “potholes”.
The needle is bent. Remedy is to straighten it. Normally the bend is just above the top of the bulb. It is done with just fingers and eyes. Rotate to see which way it needs to go. Bend a little. Repeat.
The bulb being pushed too far up the rod. Remedy is to push it back down. See the above photo with measurements.
Worn float seat hole. The float valve seat is part of the float top. It is the tiny hole at the bottom of the small hole. Examine the hole with a magnifier. It should be perfectly circular and free of nicks and scratches. Polish it with a spinning tooth pick, or the stalk of a Q-tip.
Float bulb has gasoline inside it. If the float too heavy, it won’t have enough buoyancy to stop the gasoline from getting in. Remedy is to evacuate the fuel with compressed air, locate the leak hole, and apply a minimal amount of fuel tank sealant.
