Pagina 1 van 5
Tomos DMP 70cc sprinter
Geplaatst: 11 feb 2011 18:53
door cerar_slo
Re: Tomos DMP 70cc sprinter
Geplaatst: 11 feb 2011 18:57
door Jan de Lasser
looks nice...only needs some paint?
Geplaatst: 11 feb 2011 19:03
door cerar_slo
But I have a problem: when I open full gas this happens
http://www.youtube.com/watch?v=iuhTdXqd11k
I use 17.5 YSN carb with 85 main nozzle (on the tape is 90). Now with 85 and without air filter it goes better, air needle
is almost fully unscrewed.
Before today I had connected RED and GREEN connection. Today I connected tube only on RED connection and sealed the tube on other side. GREEN connection is free open.
Any ideas how to repair this?
I would be very thankful
Geplaatst: 11 feb 2011 19:05
door cerar_slo
Jup, I decided to make it drivable, when I'll see everything is OK, im going to paint it
Geplaatst: 11 feb 2011 19:59
door 2pac
Nice
Puch cilinders are very fast on a tomos
Geplaatst: 19 feb 2011 20:58
door drestar
tastes differs, I find this nothing, but that brake in front looks good,
Geplaatst: 02 mar 2011 19:07
door cerar_slo
Today I took sprinter to pieces and started to grind it...
Geplaatst: 02 mar 2011 22:10
door Fakemon
Your front wheel is the wrong way around.
Geplaatst: 02 mar 2011 23:33
door drestar
i think that it have been done on purpose to assemble the brake claw at the good side of the foreleg?
Geplaatst: 04 mar 2011 15:26
door cerar_slo
jep, wheel is turned because of dics braking
Geplaatst: 04 mar 2011 15:29
door Fakemon
Then nevermind I said a thing.
Geplaatst: 14 mar 2011 19:19
door cerar_slo
little update
now im busy with back of the frame (seat)
finished
in progress
Geplaatst: 14 mar 2011 19:40
door 2pac
oehh very nice
Geplaatst: 15 mar 2011 17:44
door cerar_slo
today I was grinding the seat and correct faults, holes...
and I get this:
http://www.tomoshop.nl/catalog/topracin ... p-805.html
what do you think about that head (squish), is OK or to wide squish bend
http://i537.photobucket.com/albums/ff33 ... C00983.jpg
squish clearence (from piston to head): 0.85mm
squish bend: 10mm
bore: 45mm
volume is about 65.5-6ccm, compression is strong
Geplaatst: 18 mar 2011 18:44
door cerar_slo
some more pics, now i need to use more genteel sand paper
Geplaatst: 18 mar 2011 18:49
door Fakemon
Starting to look better and better.
Geplaatst: 05 apr 2011 20:00
door cerar_slo
update
wheels are finished, except i need to buy new bearings
hope u like it
Geplaatst: 05 apr 2011 20:03
door drestar
Yes,i like it, it looks very nice,
Geplaatst: 05 apr 2011 20:39
door 2pac
Nice its gonna be a pretty fast an good looking tomos
Geplaatst: 05 apr 2011 21:14
door JesseJeremy
Looks very very good, seriously.
