Tomos airsal 65cc
Rookie junior
Berichtdoor Rookie junior » 22 okt 2009 16:23
Hi!
Is there any difference in performance if you remove the wall of the booster?
like on this picture:
rikvg
Berichtdoor rikvg » 22 okt 2009 19:12
booster?
It looks like a normal(fast) cilinder to me, please explain it a bit ;)
-65cc DMP snel
-Bullet chroom
-15/15 Dellorto
Mallosi v1 klep membraam.
Snorkop: maximaal afgevlakt
Snelheid: 74,3 km/u
Uiterlijk:
DMP Carbon voorkapje.
32 cm Chrome vering
Chrome achterbrug
kappen custom paint
Demper kleur frame
rikvg
Berichtdoor rikvg » 22 okt 2009 19:19
ooh at the inlet of the cilinder, It makes some difference indeed, but its not really wise to do so.
There is a too big hole in the cilinder wall in wich your piston ring can get stuck behind which will screw up your cilinder.
I drove a while without that piece, and its not a very good solution to go harder.
Instead you could use a bigger carb or better exhaust.
-65cc DMP snel
-Bullet chroom
-15/15 Dellorto
Snelheid: 74,3 km/u
Uiterlijk:
32 cm Chrome vering
Chrome achterbrug
kappen custom paint
Demper kleur frame
Berichtdoor Timo » 22 okt 2009 19:51
It's not the best way to create more speed...
Rookie junior
Berichtdoor Rookie junior » 22 okt 2009 21:20
thanks for the advice and expalnation.
Berichtdoor Timo » 22 okt 2009 21:44
And it's not very effective at all.
