Airsal a35 cylinder head gasket?
16 berichten • Pagina 1 van 1
granturismo
Berichtdoor granturismo » 29 sep 2010 07:02
Hello,
Sry I dont speak dutch but this forum is great :-)
Anyways. I have a flexer eu25 2006. Airsal 50cc kit and a DMP cylinder head. Question is: Do I need the cylinder head gasket wich is 1.0mm thick?
Thanks
EDIT: Compression is 9Kg.. good or can be better?
Laatst gewijzigd door granturismo op 29 sep 2010 15:10, 2 keer totaal gewijzigd.
2pac
Contacteer 2pac
Berichtdoor 2pac » 29 sep 2010 08:18
Yes you need a gasket :P
Do you have pictures of your moped
-Rust in vrede Jan de lasser-
Tomos是颇有几分不同你知道
Joren
Berichtdoor Joren » 29 sep 2010 10:49
You can try it whitout the gasket, but check if the piston is not hitting the cylinder head.
whitout gasket will result in more compression = more power =)
Fakemon
Berichtdoor Fakemon » 29 sep 2010 11:59
But if the piston is hitting the head it doesn't have much use, hehe.
Nice to see some foreigners around here though, at least that shows how great Tomos is. :evil:
As people say: Try it. If it's possible to use it without the gasket it's okay. But if it starts ticking against the head it's a big NO.
granturismo
Berichtdoor granturismo » 29 sep 2010 14:53
I thought Quadro came without head gasket from factory? Or maybe it is thinner?
This is my moped. It's not finished yet. But see the dutch inspired orange springs, and later there will be "TOMOS" in orange painted on the sides :P
Laatst gewijzigd door granturismo op 29 sep 2010 15:00, 1 keer totaal gewijzigd.
granturismo
Berichtdoor granturismo » 29 sep 2010 14:59
I have made a thinner copy (got help at a factory), wich is 0.5mm instead of 1.0mm. Both in aluminium. Will try that first :) Or somehow measure the distance between the piston and head..... :)
granturismo
Berichtdoor granturismo » 29 sep 2010 15:06
Haha well that's not so good i've heard :wink: .
No idea if the DMP head has same measurement as eu45/quadro. I got 9Kg of compression now, instead of 5 before btw.
I'm not that far away... I'm swedish, but tomos is cool :P
Fakemon
Berichtdoor Fakemon » 29 sep 2010 16:06
It's kinda far away.. Hehe. But still, if everyone knew Tomos was great.. That'd be a better world wouldn't it?
Anyhow, if you just put the cylinderhead on and give it a light kick, and it ticks; you know not to use it without gasket. But if it just works it's okay. Tell us what you did, that's always handy to know. :p
Do you have a lot of trouble getting parts for your Tomos there btw?
granturismo
Berichtdoor granturismo » 29 sep 2010 18:37
Takes a while on a moped I guess :) Yes, I've actually emailed Tomos to do some marketing here and bring more models. Right now only Flexer EU25 is sold :(
Didn't work.. the piston hitted the sparkplug. So I went back to the 1mm gasket. I think I need to upjet also... higher comp=upjet?
Original parts for all Tomos ever sold here is easy obtained. But worse on tuning parts...
Fakemon
Berichtdoor Fakemon » 29 sep 2010 18:42
I see.. Must suck that you're having a hard time to get all the tuning parts. I mean I have, in a 10 kilometer radius, about 5 differnet shops for it.
And what exactly do you mean with the higher comp?
I think everything should be working properly with the 1mm gasket.
granturismo
Berichtdoor granturismo » 29 sep 2010 19:34
Tomos is a small brand here, so most shops don't have tuning parts for it :(
Before I had the original eu25 cylinder head and 5 kg compression. Now with DMP head I got 9 kg.
It was running rich before.. but guessing it's running lean now instead
Fakemon
Berichtdoor Fakemon » 29 sep 2010 19:36
Depends. How does your spark plug look by now?
Is it black: Running too rich.
Is it white: Running too low.
Is it coffee with milk: ( so brown-ish ) then it's okay.
granturismo
Berichtdoor granturismo » 30 sep 2010 16:40
I haven't tried it yet. Will a plug chop work with a used spark plug or do I need a new one? And does it need to cool down to get the correct color?
granturismo
Berichtdoor granturismo » 30 sep 2010 21:26
Crap! The angle from the Airsal exhaust port is very different. Had a gap at the back, where the pipe is connected :(
JesseJeremy
Berichtdoor JesseJeremy » 30 sep 2010 21:51
you mean diffrent from the gasket ?
Pack'r number 2
Youngster 2008 Sold
Vespa SI Sold
Berichtdoor shadowranger » 30 sep 2010 22:39
Nope, different exhaust port angle, like between A5 and A55 cylinder. See his other topic. Probably an Airsal for Puch or so.
Gebruikers op dit forum: Bing [Bot], Semrush [Bot] en 11 gasten
