what performance do you gain from a hpi cdi?
19 berichten • Pagina 1 van 1
skyline3116
Berichtdoor skyline3116 » 04 mar 2007 17:48
Hi its my first post and i live in the US. I have a 2005 tomos lx and was wondering what gains would be seen from a hpi cdi and performance ignition. I dont speak dutch so if its already been explained sorry :D Also i i have an airsal kit and want to see some pictures of how to match the transfer ports.
prutser
Berichtdoor prutser » 04 mar 2007 18:47
Your acceleration will be mutch better ...mutch better gas reaction...but beware for the power you will get,..it might damage your airsal cilinder kit...
you muts need an good spark plug ,...check your clutch weekly...if you use your moped every day its not smart to install this ignition on your tomos...could you explain your second question , than I will try to give the right answer,...
umm...45?...jewelll
skyline3116
Berichtdoor skyline3116 » 04 mar 2007 18:57
Ok i do ride my moped a lot so i guess i will pass on the cdi. The second question was to see some pictures of matching the engine cases to the airsal kit. Also what would the best carbeurator for this engine. I am already making a new intake manifold for a newer carb but i just want to know what carb is the best to buy and the easiest to tune. This is my moped
Afbeelding :D
DOes anyone have any pictures for doing this for an airsal?
Paul123
Berichtdoor Paul123 » 04 mar 2007 19:14
Carburateur: you can go and buy an 16/16 carburateur. This should run nicely together with you airsal kit. If you have the money, and are not worried about petrol consumption you can buy an 19mm carburateur by dell'orto. Dont tune your carburateur, it's quite useless in a way.
To create the transfer ports inlet you can best take the gasket from your airsal cilinder and draw with a highlighter or something the shape it shows onto your carters. (the metal part)
then with a dremel, or with a different machine cut this shape into the metal so more petrol can enter via your transfer ports.
This is not easy though, and if incorrectly done it can seriously harm your moped.
By the way; i love your petrol tank :O 8)
Doe gezond, rook een appel.
skyline3116
Berichtdoor skyline3116 » 04 mar 2007 19:20
I will fully disassemble the engine before using the dremel and do you know what jets to use for the dellorto 19mm? Do you think i should get another cylinder kit for daily use or is the airsal ok? And when i said tune the carb i meant making it run correctly and making the fuel mixture correct for the engine. Thanks
Paul123
Berichtdoor Paul123 » 04 mar 2007 19:22
The jets that you have in your daily carburateur at the moment also fit in there.
The airsal is a good cilinder kit, if you want a better one. It is best to get a puch cilinder kit. Puch cilinder's are there in more variation and cc's. But overall i would say, stick with the airsal.
skyline3116
Berichtdoor skyline3116 » 04 mar 2007 19:26
Yes i was thinking of getting a 80cc mk but i hear the tomos clutches tend to fall apart with it. What else do you think can be done to enhance performance. Thanks again with the help. Also is there anyway to buy an led taillight for my tomos? Wish i could read dutch! here is a pic of my moped about a year ago
Volty
Berichtdoor Volty » 04 mar 2007 19:56
OMFG! That's a bunch of bullsh*t! A HPI ignition doesn't EVEN give a performance boost, it only gives a better throttle reaction, and it's possible to run the engine at higher revs. Nothing more!
For daily usage I should recommend your 65cc Airsal cylinder with a 15 or 16mm dellorto carburator. Forget the 80cc MK, that's not even a direct fit :P
And yes, there are LED taillights for sale here, but i dunno if you can buy them in the usa too. Maybe you can call some electronic shop for creating a led taillight for you?
Nice tomos btw!
Berichtdoor Vuile Beunkoe » 04 mar 2007 22:48
You? Giving a right answer?
* NOOB ALERT *
A HPI Ignition is a pricefull thing. I would only buy it when I had won the lottery :') . Serieus, a original tomos CDI ignition is good enough for on the streets. You dont have to worry of the HPI causing damage to your clutch / engine. When rightly tuned, it will be something to enjoy (You may expect that for such a price)
And ofcourse, nice tomos, but please grind the engine/front light plastic off :P
prutser
Berichtdoor prutser » 05 mar 2007 16:17
...hier heb ik er 2 staan...alle 2 airsal 70 cc afgevlakte 70 kop ..alle 2 16 mm ...één met hpi en zonder hpi...
en waarom trekt die met de hpi onteking beter op...??..omdat het een binneroter is...misschien...
en hoe kan het als dat die met hpi om de 3 weekjes een setje 1e versnelling koppelingssegmenten er doorheen trekt?...
en lul aub niet dat het aan de koppeling ligt...want die zijn gewoon waardeloos van tomos...
ik laat het verder maar aan jullie over...mijn reactie word tog niet serieus genomen..
umm...45?...jewelll
NOS_Tomos
Berichtdoor NOS_Tomos » 06 mar 2007 22:46
That Tomos looks sick, really cool! I see that you have pedals:P Is you gas tank removable? and are those plastic covers and gas tank available in the US?
You can buy LED Lexus taillights here in the Netherlands. Maybe one of us can send you one?
guys?
Tomos A35: 65cc Airsal, 16/16 dell'ortho en een Yasuni Carrera 16.
skyline3116
Berichtdoor skyline3116 » 07 mar 2007 22:35
It would be great if i could get that led tailight. I would be willing to pay for everything. Yes in the us they sell like that. This is a picture of when i first bought it. go to tomosusa.com and you can see how they sell there
NOS_Tomos
Berichtdoor NOS_Tomos » 07 mar 2007 22:55
I think that we could arrange something. do you have MSN messenger?
mines is thomasbudry@hotmail.com
grtz
skyline3116
Berichtdoor skyline3116 » 08 mar 2007 00:08
No but i have skype and aol instant messenger and yahoo messenger. I will be sooooo happy if i get it. I will probably be the only one to have it in the country!!! :)
NOS_Tomos
Berichtdoor NOS_Tomos » 08 mar 2007 13:31
Well, I think that we could work something out :) If you are willing to pay for everything, then i would be glad to buy you an LED and to send it to the USA, you can add windows live messenger friends with Yahoo messenger. so please add me: thomasbudry@hotmail.com
Grtz. Thomas
skyline3116
Berichtdoor skyline3116 » 08 mar 2007 21:26
sorry i dont think it worked when i tried to add you. Ill just get msn messenger and add you there.
NOS_Tomos
Berichtdoor NOS_Tomos » 08 mar 2007 21:29
No need, i already made a yahoo account thomasbudry is the name to add
skyline3116
Berichtdoor skyline3116 » 09 mar 2007 03:48
ok great talk to you on there tomorrow!
Berichtdoor Vuile Beunkoe » 09 mar 2007 12:39
please do this by private message... No need to spam the topic with it ^^
Terug naar “Opvoeren”
Gebruikers op dit forum: Majestic-12 [Bot], Semrush [Bot] en 4 gasten
