Re: Hello from LE, my first Tomos
Geplaatst: 27 feb 2022 12:37
door Wolfram
Geplaatst: 27 feb 2022 14:16
door shadowranger
Nice!
Have fun driving.
Geplaatst: 06 mar 2022 08:09
door Wolfram
Hi all,
that moped really makes fun. So easy to start and simple and robust technique. I like Tomos!
Geplaatst: 21 apr 2024 19:31
door Wolfram
Salut drivers, after some work on other projects, I had again a look at the tomos who is used by my neighbor. It starts perfectly but it doesn't turn high enough. I assume maximum 6000 rpm, then it starts stumbling. Maximum 59 km/h on the meter, maybe 45 real. Carburetor is clean, new Dellorto 15 mm not original and flow of gasoline is also fine. Can I adjust the ignition point perhaps?
I'm open for some hints for improving.
Regards/adios/cordialement wolfram
