2006 Flexer shifts gear too early!
11 berichten • Pagina 1 van 1
granturismo
Berichtdoor granturismo » 15 jun 2012 15:36
Hello,
I write in english, hope its ok :) My flexer 2006 shifts gear too early... i want it to shift around 20-25 km/h, but it shifts at 5-10 km/h, and the other way around.. down at 10, instead of 25..
Anyone know where to buy new springs for the gearbox? Or harder springs
Thanks in advance!
EDIT 2: My clutch ---> http://img802.imageshack.us/img802/4079 ... 010220.jpg
I accidently cut the spring too much, so need new spring....
Laatst gewijzigd door granturismo op 16 jun 2012 01:13, 1 keer totaal gewijzigd.
Berichtdoor Alex.. » 15 jun 2012 17:43
you can shorten the spring bij a few mm's (the more you remove from the spring the later it will shift)
be careful not too shorten it to much, use incremental steps and stop when youre satisfied.
you will need some leverage to get the shortened spring back around it.
15melvin15
Berichtdoor 15melvin15 » 15 jun 2012 19:30
you need a new clutch, its complete worn out.
Berichtdoor Alex.. » 16 jun 2012 00:41
i did not see the picture (was on mobile), melvin is right, the clutchlining is completly gone, when you search the wiki here you can see how you can make your own lining (or just order it)
if you need any help translation feel free to ask
granturismo
Berichtdoor granturismo » 16 jun 2012 00:58
Oops, i forgot to say, the image was only to represent how the spring looks like. Not my clutch. I will take a picture of mine.. one second
Edit: Here is MY clutch this time. Also, I cut the spring too much so I need a new one :/
granturismo
Berichtdoor granturismo » 16 jun 2012 02:22
Found at http://www.tomoshop.nl :D wooooo
1st gear 209013
2nd gear 223769
Berichtdoor shadowranger » 16 jun 2012 10:24
@ 15melvin15: On what base do you say that the clutch is completely worn? As far as i can see at the picture i noticed that only the main spring is cut at the end. The cork on the segments is fine as far as i can assess.
Just buy a new spring, or get a second hand one from another part. You can try to bend the broken end to a new hookloop.
@Granturismo: Your link isn't working, you don't send link to part, but homepage.
Because this is in English, i will move this to our English forum.
15melvin15
Berichtdoor 15melvin15 » 16 jun 2012 16:40
i'm afraid u cant buy just the spring.
http://www.themopedjunkyard.com/A35tomo ... ssion.html
That's where I found the complete clutch.
Berichtdoor Ping » 16 jun 2012 16:51
:x :x :x :x :x :x :x :x :x :x :x
http://www.q-parts.nl/catalog/index.php ... ers_id=100
€ 3,25 A PIECE
granturismo
Berichtdoor granturismo » 16 jun 2012 21:36
Thanks all for help! Springs are ordered. I will get back once they are mounted with the result.. might take a while, because I dont have so much time to work with my moped right now.
@Shadowranger
http://www.tomoshop.nl/catalog/kopp-vee ... -1035.html 1st gear spring 2.50 Eur
http://www.tomoshop.nl/catalog/kopp-vee ... -1036.html 2nd gear spring 2.50 Eur
@Ping 2.50 Eur ;-)
Berichtdoor Ping » 16 jun 2012 21:39
thats even better 8)
it was more the example , that they are available as seperate items :wink:
