Tomos Flexer wiring diagram
granturismo
Berichtdoor granturismo » 13 apr 2014 22:00
Hello!
I have a 2006 Tomos Flexer, and I need wiring diagram how to connect the engine to the cdi-unit and the "silver-thing" that makes AC to DC (or the other way around).
Cheers!
Berichtdoor shadowranger » 14 apr 2014 11:05
Is this what you're looking for? Click on the image to enlarge it.
Next time, please search our wiki section. It's in Dutch, maybe you need to translate to your native language by Bing or Google Translate. There you can find many items like yours.
Your part is located in the top right of the image called "Spanningregelaar 12V 60W". Wiring is from left to right: Blue/Blue (D+ from ignition), Yellow/Yellow (12volts AC), White (12volts DC) and Brown/Brown (Ground). On the terminals of the "Silver thing" which are labeled you can connect the wiring to
